G15 Cube Servo and ioio
Postby zargoun » Sun Apr 13, 2014 10:19 am
im tring to control the G15 servo using IOIO board,
i have done a code to send the data packets to the G15. However the motor doesn't response at all.
i have connected the ioio board to computer throw hypertirmenal to check the data, the was sent by IOIO board perfectly
the question is "if i sent data packets just like in the user manual, is that should move the motor or not ?"
 int availableBytes = 0;
  try{
   DTR.write(tx);
    try {
          out.write(0xFF);                          //the library waits for transfer complete, output.flush() is called
         out.write(0xFF);
         out.write(0x01);
         out.write(0x07);
         out.write(0x03);
         out.write(0x1E);
         out.write(0x20);
         out.write(0x02);
         out.write(0x47);
         out.write(0x02);
         out.write(0x6C);
         delay(20);
    catch (IOException e){
    DTR.write(rx);
    try{
    availableBytes = in.available();
     println(availableBytes);
    if (availableBytes > 0 && bufferOffset + availableBytes < readBuffer.length)
          try
            bufRd.read(readBuffer, bufferOffset, availableBytes);
            e.printStackTrace();
    } catch (IOException e) {}
  } catch (ConnectionLostException e){
zargoun
Re: G15 Cube Servo and ioio
Postby tonywk88 » Sun Apr 13, 2014 10:32 pm
Do check if the G15 motor is in 'Wheel' mode or 'Position' mode.
If the G15 is set to 'Wheel' mode, It will NOT work if you trying to sent the position to the motor.
Thanks
tonywk88
Postby zargoun » Mon Apr 14, 2014 9:11 am
tonywk88 WROTE:Hi,
Thanks
is the motor going to be in wheel mode by default ?
zargoun
Postby zargoun » Mon Apr 14, 2014 9:51 am
tonywk88 WROTE:Hi,
Thanks
i have tried to turn on the LED and torque using the code in manual, but i have not succeed to turn it
         out.write(0xFF);
         out.write(0x01);
         out.write(0x05);
         out.write(0x03);
         out.write(0x18);
         out.write(0x01);
         out.write(0x01);
         out.write(0xDD);
zargoun
Postby Idris » Tue Apr 15, 2014 8:54 am
Hi zargoun,
When you power up the G15, LED on G15 will blink once. This indicator show G15 is still in good condition. So, make sure this happen.
I assume you are using GD02 driver, so you need to control the CTRL pin to make the GD02 in transmit or receive mode. So my idea, try to set the GD02 as transmit only and control the G15 LED (like do blinking 1 sec). Plus in your program, just do transmit, ignore the receive part. This idea just want to troubleshoot on the communication part between IOIO and G15. Once this working, you can slowly do on receive part.
Anyway, could you post your current hardware and wiring pictures?
Postby zargoun » Wed Apr 16, 2014 9:23 am
Idris WROTE:Hi zargoun,
yes i can see the LED blink once, and im sure that motor works very well because i can control it using windows GUI
do i need to make a pull-up resistor for the DTR pin ?
the photos of the hardware are below
this is the code for the LED blinking
void ioioSetup(IOIO ioio) throws ConnectionLostException {
  uart = ioio.openUart(4, 6, 19200, Uart.Parity.NONE, Uart.StopBits.ONE);
  led = ioio.openDigitalOutput(IOIO.LED_PIN, true);
  DTR = ioio.openDigitalOutput(3, true);
  in = uart.getInputStream();
  out = uart.getOutputStream();
void ioioLoop(IOIO ioio) throws ConnectionLostException {
  led.write(false);
  try {
    DTR.write(false);
    try {
         out.write(0xFF);
         out.write(0xFF);
         out.write(0x01);
         out.write(0x05);
         out.write(0x03);
         out.write(0x19);
         out.write(0x01);
         out.write(0xDD);
         delay(2000);
         out.write(0xFF);
         out.write(0xFF);
         out.write(0x01);
         out.write(0x05);
         out.write(0x03);
         out.write(0x19);
         out.write(0x00);
         out.write(0xDF);
         delay(2000);
    Thread.sleep(20);
  catch (InterruptedException e) {
here is the data from hyperterminal
try {
         out.write(0xFF);
         out.write(0xFF);
         out.write(0x01);
         out.write(0x05);
         out.write(0x03);
         out.write(0x19);
         out.write(0x01);
         out.write(0xDD);
         out.write('A');
         delay(2000);
         out.write(0xFF);
         out.write(0xFF);
         out.write(0x01);
         out.write(0x05);
         out.write(0x03);
         out.write(0x19);
         out.write(0x00);
         out.write(0xDF);
         out.write('B');
         delay(2000);
zargoun
Postby Idris » Wed Apr 16, 2014 4:31 pm
Zargoun, nice project!
Anyway, you can use RealTerm as terminal software to display data in HEX.
Postby zargoun » Wed Apr 16, 2014 5:10 pm
Idris WROTE:Zargoun, nice project!
i have use realterm to display, all the bytes been sent correctly as shown in the picture below
i feel that DTR pin is the problem, but i have tried everything to make it work
do i have to to do anything before i send these bytes such as baudrate setting for the motor, because the way i do it is as following:
i turn on the motor, then directly send the bytes
zargoun
Postby Idris » Thu Apr 17, 2014 9:18 am
To set the GD02 in transmit mode, make sure CTRL pin is HIGH, you can measure using multimeter.
Try this,
Turn ON LED
Byte 1: 0xFF // Header
Byte 2: 0xFF // Header
Byte 3: 0x01 // G15 ID
Byte 4: 0x04 // Length (Parameter + 2)
Byte 5: 0x03 // Write instruction
Byte 6: 0x19 // G15 LED address (Parameter 1)
Byte 7: 0x01 // Turn ON LED (Parameter 2)
Byte 8: 0xDD // Checksum
Turn OFF LED
Byte 7: 0x00 // Turn OFF LED (Parameter 2)
Byte 8: 0xDE // Checksum
Postby zargoun » Thu Apr 17, 2014 11:27 am
Idris WROTE:To set the GD02 in transmit mode, make sure CTRL pin is HIGH, you can measure using multimeter.
Try this,
Turn ON LED
Turn OFF LED
yes it works, thank you very much
my mistake was i connected the RX>TX and Tx>Rx but actually it must be Rx>Rx and Tx>Tx
plus the mistake from the bytes value
thank you
zargoun
