does G15 Servo have internal controller ??
Postby zargoun » Wed Apr 23, 2014 5:19 pm
i have bought and chose the G15 because it has a feedback, but i found out that the feed back all about the errors and checksum.
does the G15 have internal controller ?? if yes what type of controller ?
and how can i get more information about this controller ?
Thank you
zargoun
Re: does G15 Servo have internal controller ??
Postby yonghui » Fri Apr 25, 2014 9:52 am
G15 is a digital servo, for sure it has an internal controller. what kind of feedback do u want from G15? u can check the control table of G15 in the user manual to see variables that u can retrieve from G15.
Postby zargoun » Sat Apr 26, 2014 8:47 am
yonghui WROTE:G15 is a digital servo, for sure it has an internal controller. what kind of feedback do u want from G15? u can check the control table of G15 in the user manual to see variables that u can retrieve from G15.
what i meant by controller is "PID controller" "fuzzy logic controller" or others
ohhh i found the feedback i want, thanks for opening my eyes
37 (0x25) Present Position (H) R
38 (0x26) Present Speed (L) R
39 (0x27) Present Speed (H) R
40 (0x28) Present Load (L) R
41 (0x29) Present Load (H) R
but there is no any example about this, can anyone tell me what are the bytes i should send to receive the present position ??
zargoun
Postby yonghui » Wed Apr 30, 2014 11:30 pm
u can try look further the usermanual. There is a part that mention the packet format. Start sending header,id,packet length,address to read,checksum extra in correct packet format, G15 will reply u what u needed. Got example packet in last section of usermanual too. G15 is using trapezoidal control algorithm which u can also adjust according to your system load. Refer to user manual for more info on that.
