My G15 LED is blinking and motor not moving, HELP!!!
Postby whatsap45 » Fri May 23, 2014 4:01 pm
AS TITLED, my g15 motor is not moving and the led keeps on blinking, what to do?
whatsap45
Re: My G15 LED is blinking and motor not moving, HELP!!!
Postby A380 » Fri May 23, 2014 4:19 pm
It might be overheat error or overload error occurred. Is it possible you read the G15 feedback "Error Byte"?
A380
Postby whatsap45 » Fri May 23, 2014 4:36 pm
how to read error byte?
whatsap45
Postby whatsap45 » Fri May 23, 2014 4:39 pm
problem solved, its overload issue, thanks :)
whatsap45
Postby acsamuel@gmail.com » Mon Aug 25, 2014 6:48 pm
Whatsap How did solve the problem,
Cytron how do i reset a overload error?
acsamuel@gmail.com
Postby yonghui » Tue Aug 26, 2014 2:38 pm
there are two common reason for G15 to blink its LED.
1. Overload. G15 will off its torque when overload. Please release G15 to let it free running without connecting any load to G15 shaft. power off and on G15 to reset the overload error in order to let G15 run normally again.
2. overHeat. power off G15 and let it cool down for few minutes before turning on G15 again.
