What is the maximum torque G15 can withstand by default?
Re: What is the maximum torque G15 can withstand by default?
Postby yonghui » Tue Jun 10, 2014 7:49 pm
I mean if use shield lib for gd02
Sent from my Nexus 4 using Tapatalk
Postby yonghui » Tue Jun 10, 2014 8:03 pm
Every packet sent to g15 will be replied by g15 with error bytes. In the example in library reference U can see the stat contains all the alarm or error byte of g15 as described by the return status of the library ref
Sent from my T100TA using Tapatalk
Postby whatsap45 » Wed Jun 11, 2014 12:59 pm
To yonghui,
Okay, i understand this shows the status of the G15 in terms of Return packet error and servo packet error in 2 bytes. My question is, how to access from it ???? As in, how to read it using Arduino UNO programming language or do i need external software to access the Return Status? I need the 2 bytes value to be displayed and visible for me to see...
To sich,
Can you kindly reply my question? thanks :)
whatsap45
Postby yonghui » Wed Jun 11, 2014 1:47 pm
for example i set the torque:
word stat;
stat = servo1.SetTorqueLimit(512);
here, the stat is the variable that u get all the error and alarm.
the variable stat contains 16 bits of error status and alarm status as following:
Bit <Return Packet Error>
15 --
14 --
13 --
12 --
11 Checksum error
10 ID mismatch
9 Wrong header
8 Packet lost or receive time out
Bit <Servo Returned Error>
7 --
6 Instruction error
5 Overload error
4 Checksum error
3 Range error
2 Overheating error
1 Angle limit error
0 Input voltage error
the lower 8 bits are servo's alarm status. the higher 8 bits are return packet error.
so if u wan to know if overload occur, just check the bit 5 of stat:
byte overloaderr;
overloaderr=stat&0x0020;
if u wan to check any of error occur just read the stat value if it is more than 1 then means got error.
if (stat&0xFF00)
// return packet got error
if (stat&0x00FF)
//G15 alarmed for certain error
Postby whatsap45 » Thu Jun 12, 2014 2:24 pm
Alright, let me digest first haha ... thanks ar... :)
whatsap45
