Solar Tracker Motor
Solar Tracker Motor
Postby reno » Sun Oct 12, 2014 9:10 am
helloo guys.. im doing a dual axis solar tracker for my fyp. im having a problem about the motor. what is the best and cheap motor can be used for this solar tracker?? is it a DC motor?? what kind ?? thanx... :)
its not mine, but maybe im doing similar like this
reno
Re: Solar Tracker Motor
Postby ober » Mon Oct 13, 2014 12:25 pm
You may check out the SPG30E, get high torque version to provide enough power to drive your mechanism.
Postby reno » Tue Oct 14, 2014 7:56 pm
tq Mr Ober for the reply..im not really sure about the DC Geared Motor with Encoder, but later i will check the information about it..anyways,thanx again Mr Ober..cheerss.. :D :D
reno
Postby reno » Fri Oct 24, 2014 7:47 pm
hello again guys..emm,is the DC gear motor SPG20/30/50 series can turn clockwise and anti clockwise ?? tq :D
reno
Postby yonghui » Sat Oct 25, 2014 9:06 am
normally all motor can turn clockwise or counter clock wise. U will need motor driver with H bridge to do it. Try look at cytron motor driver and motor driver shield
