Suitable DC motor for Balancing Robot
Re: Suitable DC motor for Balancing Robot
Postby ober » Fri Sep 25, 2015 8:11 am
We can only recommend for you to test, if the motor is not enough power, you need to either:
- Change the motor to higher ratio gear, but this will reduce the speed.
- Change to higher power motor.
- Reduce the weight of robot.
- Reduce the wheel size to increase the effective torque of robot.
