G15 Cube Servo Orientation
PostPosted: Fri Oct 21, 2016 11:59 am
by afz2004
Hello guys, I want to ask something. I little bit confused and kinda lost too about how I am going to set the servo. I have 3 G15 Servo Motor. Basically, first motor say it will move 30 degree CW, second motor, 50 degree CCW, and last 20 degree CW.The question, how I able to control the direction while limiting the angle number?I know in coding, I have to set 3 different ID. How bout baud rate, can all be the same? Here I attach preview of the code:
#include <SoftwareSerial.h>
#include <Cytron_G15Shield.h>
#define G15_1 26 //Cube Servo ID
Cytron_G15Shield g15(8); // HardwareSerial + Control pin
    Serial3.begin(19200);
    g15.begin(115200);
    g15.exitWheelMode(G15_1);
    //pinMode(9,OUTPUT);
void loop() {
  int val;
  int prevVal;
  char gov;
  int hoho=0;
   if (Serial3.available())
      val=Serial3.parseInt();
      if(val>30 && val<70)
        hoho=70;
      else if (val>5 && val<30)
        hoho=80;
      switch(hoho)
        case 70:
        g15.setLED(G15_1, ON);
        delay(10);
        g15.setLED(G15_1, OFF);
        g15.setSpeed(G15_1, 100);
        g15.setWheelMode(G15_1,100,CCW);
        g15.setPosAngle(G15_1, 90); // Set G15 (ID = 1) position to 90 deg
        break;
        case 80:
        delay(10);
        g15.setPosAngle(G15_1, 180); // Set G15 (ID = 1) position to 90 deg
        break;
        default:
        delay(300);
        g15.setSpeed(G15_1, 200);
        g15.setPosAngle(G15_1, 0); // Set G15 (ID = 1) position to 90 deg
p/s: code above is not picture the exact operation. for reference.
