by yuansoon » Mon May 01, 2017 12:26 am
Hi A380,
If i need to have a library for rero line sensor, can i just modify the .c ad .cpp file of g15shield and include it in the arduino? I've changed the definition of its address to what of the line sensor from the datasheet, but after i've included the library to the directory library folder, the function in the .h file i modified are not declared after i include the modified header file, do you know why?
can you take a look at the file i modified?
- Attachments
Cytron_G15Shield2.zip
- (4.54 KiB) Downloaded 1539 times
