Motor Shield MD 10 runs only one direction proper
Postby DC_trouble » Sat Sep 09, 2017 5:11 pm
Hello everybody
I have a big issue with my md10 motor shield.
It it connected to an arduino uno. The goal is to power a 24V DC-motor (4A).
If i use the test buttons, the motor works fine. But as soon as I use software to control it, the trouble begins:
During the setup stage, the motor runs slowly and unsteady in one direction. After that stage, I can control it in one direction properly. But as soon as I stop it (pwm output 0), it again runs slowly and unsteady, like at the beginning.
When i change the direction, it hardly reacts to my input. High speed is unreachable. The onboard LEDs then both flicker.
This also occures when I use the example code (provided by Cytron). One direction is ok, the other not at all.
Further information:
I am a mechanical engineer student, currently working on my master thesis. The hardware is new (arduino one and motor shield). The motor is new as well, powered by SPS power supplies.
I am desperately hoping for some help. Thanks in advance.
Kind regards
DC_trouble
Re: Motor Shield MD 10 runs only one direction proper
Postby Idris » Mon Sep 11, 2017 6:21 pm
Hi DC_trouble,
Since the test button is working fine, it seems like the trouble might be from the program. Could you share a few clear photos of your hardware setup and also the Arduino coding (the first one, before using example code)?
Postby DC_trouble » Tue Sep 12, 2017 4:08 pm
Hi Idis
I did some more testing this morning:
When i set the direction to "LOW", everything works perfectly fine. The other direction "HIGH" does not work at all (no slow movement, no unsteady movement. just no movement at all).
I checked, if the arduino direction pin really sends a signal if set high. I connected a LED to the direction output pin, it works.
The motor shield test buttons both work (both directions ok!).
The Code:
int dirpin=2;
int motorpin=3;
void setup() {
pinMode(dirpin, OUTPUT);
pinMode(motorpin, OUTPUT);
void loop() {
analogWrite(motorpin, 50); //works fine
digitalWrite(dirpin, LOW);
delay(2000);
analogWrite(motorpin,0); // works fine
delay(2000);
analogWrite(motorpin, 50); //does not work at all, no movement!
digitalWrite(dirpin, HIGH);
delay(2000);
analogWrite(motorpin,0); // works (no movement)
delay(2000);
The jumper positions don't have an influence. I tried all possibilities and changed the wiring respectively. The Arduino signal is ok (LED test). And since the test buttons both work, I expect the power supply to be ok.
One more comment: The picture "Shield_heat" shows an area, which heats up as soon as i connetct the 24V DC to the shield, but without even using the motor. Is this normal?
I'm looking forward for your reply.
Regards, DC_trouble
DC_trouble
Postby DC_trouble » Tue Sep 12, 2017 9:46 pm
Hello everyone and especially Idris
Problem solved.
I didn't stack the shield on the arduino because i need to separate the control unit (Notebook, arduino) and the power unit (motor shield, motor, machine). But of course i should've connected the 5V power and the ground between arduino and motor shield. Now it is connected and everything works fine.
Thanks for the help anyways.
Regards, DC_trouble
DC_trouble
Postby Idris » Wed Sep 13, 2017 4:43 pm
Hi DC_trouble,
Glad to hear that you've found the root cause. Keep explore! :)
