Heat a borad
Heat a borad
Postby heppoko » Fri Jul 06, 2018 9:08 pm
I am using to drive 24V 3A DC motor by MD10C. The board gets heat just by connecting the power supply. Temperature is about 60~70 degrees. More more heat when motor is moving. Is this normal? Not burning now but I worry to burn the board. Do I need to cool the board? Everyone use cooling fan?
I know the stress test video, it is heat until 117 degrees with no cooler. Is this no problem?
heppoko
Re: Heat a borad
Postby Idris » Mon Jul 09, 2018 5:17 pm
Hi heppoko,
It is not normal the driver heat up without load. Could you share a few clear photos/video on your hardware setup?
Re: Heat a borad
Postby heppoko » Tue Jul 10, 2018 1:09 pm
Thank you for replay.
Connectioin
I only connected from Power unit to driver. The power supply unit I use is TDK-lambda RWS150B-24.
https://www.us.tdk-lambda.com/lp/produc ... sb-series/
heat area
Turn on the power and listen carefully, I hear the high frequency sound from the driver.
I have several MD10C driver boards. Each board is the same heat. Is there any problem with the power supply unit?
heppoko
Re: Heat a borad
Postby Idris » Tue Jul 10, 2018 3:42 pm
Hi heppoko,
Thanks for the clear photos.
The area that you highlighted is 7812 regulator. The heat (on that area) is normal for 24V operation.
Thanks. :)
Re: Heat a borad
Postby heppoko » Wed Jul 11, 2018 8:53 am
Would you please tell me your thoughts on waste heat for these drivers?
heppoko
