I just ordered a MDD10A to use with 2 775 DC Motors together with an Ardunio.
I'm going to be using a 14.4 Li-po 7500mah.
I just stumbled upon this.
"Hi, Yes. You can but you need to make sure that you have to connect a battery with same voltage in parallel with the power supply for absorbing the current generated by the motor. Thanks.
So does this mean that i need 2 battery packs? Could someone please explain this?
also
What is the biggest difference between MDD10A and SHIELD-MDD10?
How is the EMF protection on these boards? Thinking for noise from the motor etc.
Thanks a lot for all the help.
