MD10C heating up in minutes after powering it up.
Postby tangapan » Thu Apr 13, 2023 11:09 am
Yesterday I bought a Cytron MD10C to connect it to a DC pump (24V, approximately 1 A) with an adapter supplying the board 24V 2.5 A. I left the MD10C on for a few minutes with and hardly tured on the motor. The driver quickly heated up even though it was idle and pump was not pulling any current.
I want the board to run for a couple of hours at a stretch. Im now thinking of adding a relay that will turn on the driver only when I want to power on the motor. But is this expected behaviour? I was under the impression that the board shouldnt heatup, especially considering Im supplying it a fraction of the ampere it is rated to handle?
tangapan
Re: MD10C heating up in minutes after powering it up.
Postby ober » Fri Apr 14, 2023 7:57 am
It’s expected as the heat is from the linear voltage regulator especially when using 24V. It should not have any problem to run it for a few hours in a stretch.
Postby tangapan » Sat Apr 15, 2023 10:49 pm
Super! Thank you very much..
tangapan
Return to DC Motor
