need help in cytron's servo motor!
Postby winz » Tue Jul 14, 2009 3:16 pm
i read your servo motor information, all those description is about servo motor with 3 wires but what i bought is with just 2 wires which is red & black line and i just cant find another line which is used for signalling.
my servo motor type is cytron C36S.
winz
Re: need help in cytron's servo motor!
Postby ober » Tue Jul 14, 2009 4:00 pm
Hi winz, I have moved this topic to DC motor, it is more relevant.
Seem like you have bought the 360 degree servo motor which have been modified. Under the product page of modified servo: http://www.cytron.com.my/viewProduct.php?pid=JxQUAxAVMDcoNjMqAB4iPEAEXJLN8nGLGDsRG6tHr!!!!!k=&store=, you will notice that the description stated there is only 2 wires and rotation of 360 degree. This is not a standard servo any more. It has become a normal DC motor with gear. You cannot control the position any more.
If you want to change the servo, please contact our sales at sales@cytron.com.my.
Postby winz » Wed Jul 15, 2009 1:49 am
i had make a request to the website to change it from modified type to a ordinary type. thanks for the reply.
winz
Postby robosang » Wed Jul 15, 2009 9:33 am
Yup, luckily I buy correct servo previously. I bought 20 pcs for my hobby project. It working fine, though I need to get a servo controller for so many servo.
Postby Are_Zamie » Mon Sep 07, 2009 8:57 am
I buy ur C17S servo motor.I have some question...is it this servo has 180degree rotation or less?? and is it use 20mS(50Hz) pulse??
Are_Zamie
Postby sich » Tue Sep 08, 2009 1:29 pm
C17S is normal RC servo motor. So you're right. It has approximately 180 degree of rotation and the signal given to it should be 20ms pulse.
Postby Are_Zamie » Wed Sep 09, 2009 9:09 pm
I totally use ur sample code on this C17S servo but it continuos rotate until at the end of its limit.Then I change the code to 1.5mS to get the centre position but the result was the same.I use PC USB 5V for supply to the PIC and the servo (I think this should be OK because this is only micro servo).I really need help on this.
Are_Zamie
Postby robosang » Thu Sep 10, 2009 11:44 am
I think that is the symptom of not enough power or wrong control signal to RC servo.... do change your power source to the servo.
Postby sich » Thu Sep 10, 2009 11:47 am
Which sample program are u using? Can u specify? Usually the timing depends on many factors such as crystal value, PIC configuration, the program flow etc. Can u make sure the pulse is really at 20ms period?
