// Author :CYTRON TECHNOLOGIES
// Project :DIY Project(PR21-Gaming with Accerlerometer)
// Project description :Use PIC18F452 microcontroller together with the ADXL330
// accelerometer to measure the gravity force and DS-LCD-TG12864B-03
// Graphical LCD (GLCD) for display.
// Include
#include <p18f452.h>
// Configuration
#pragma config OSC = HSPLL, OSCS = ON
#pragma config PWRT = OFF
#pragma config BOR = OFF
#pragma config WDT = OFF
#pragma config CCP2MUX = OFF
#pragma config LVP = OFF //configuration for the microcontroller
// Define
#define lcd_data LATD //LCD 8-bit data PORT
#define rst LATCbits.LATC4
#define rs LATCbits.LATC5 //RS pin of the LCD display
#define rw LATCbits.LATC6 //R/W pin of the LCD display
#define e LATCbits.LATC7 //E pin of the LCD display
#define psb LATCbits.LATC3
#define b_light LATCbits.LATC2 //backlight of the LCD display (1 to on backlight)
#define buzzer LATCbits.LATC0 //buzzer (1 to on buzzer)
#define sw1 PORTBbits.RB0 //button (active low)
#define sw2 PORTBbits.RB1 //button (active low)
#define z_axis PORTAbits.RA0
#define y_axis PORTAbits.RA1
#define x_axis PORTAbits.RA2
#define preset PORTAbits.RA4
#define st LATBbits.LATB2
#define channel0 0b10000001 // Configuration for read ADC channel 0 (RA0)
#define channel1 0b10001001 // Configuration for read ADC channel 1 (RA1)
#define channel2 0b10010001 // Configuration for read ADC channel 2 (RA2)
// variable
int xaxis ,yaxis, zaxis,p;
int x_off,y_off,z_off;
char d_data, d_data1;
char p_x,p_y;
unsigned int sens = 500;
signed long x_velo=0,y_velo=0,x_dis=0,y_dis=0,last_x=0,last_y=0;
char test[] = {"testing0"};
char cali [] = {" CALIBRATE... "};
char mssg1[] = {" LET IT FLAT "};
char mssg2[] = {" AND PRESS SW1 "};
char mssg3[] = {"FREESPACE "};
char mssg4[] = {"FRICTION "};
// Graphic Picture Data
rom char graphic[3][1024] = {{
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFE,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xC0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0x80,0x01,0x80,0x00,0x00,0x03,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x7F,0x80,0x03,0x80,0x00,0x00,0x01,0xFF,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xF3,0x80,0x07,0x00,0x00,0x00,0x00,0x3C,0x40,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xC3,0xB8,0xFF,0xBF,0x3E,0x1F,0xC0,0x0E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x80,0x39,0xDF,0xBE,0xFE,0x3F,0xC0,0x07,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x80,0x39,0xDF,0xBE,0xFE,0x3F,0xC0,0x03,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x80,0x3B,0x9E,0x71,0xC2,0x39,0xC0,0x01,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x84,0x3F,0x9C,0x61,0xC6,0x39,0xC0,0x01,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x8F,0x3E,0x3C,0xE1,0x86,0x73,0x80,0x01,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0xFE,0x3C,0x3E,0xC1,0xFE,0x63,0x80,0x01,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xFC,0x3C,0x3E,0xC1,0xFE,0xE3,0x80,0x01,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xF8,0x38,0x1D,0xC0,0xF9,0xE7,0x00,0x03,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xF8,0x07,0x03,0xC3,0xC7,0xFC,0x00,0x78,0x70,0x1D,0xFF,0x1F,0xE0,0x00,
0x00,0x03,0xFC,0x07,0x03,0xC3,0xC7,0xFC,0x01,0xFE,0x38,0x39,0xFF,0x1F,0xF0,0x00,
0x00,0x03,0x9E,0x0F,0x83,0xE7,0xC7,0x00,0x01,0xCE,0x38,0x39,0xC0,0x1C,0x70,0x00,
0x00,0x07,0x0C,0x0F,0x83,0xE7,0xC7,0x00,0x03,0x87,0x3C,0x79,0xC0,0x1C,0x70,0x00,
0x00,0x07,0x00,0x1D,0xC3,0xE7,0xC7,0x00,0x03,0x87,0x1C,0x71,0xC0,0x1C,0x70,0x00,
0x00,0x07,0x3E,0x1D,0xC3,0xA5,0xC7,0xF8,0x03,0x87,0x1C,0x71,0xFE,0x1F,0xE0,0x00,
0x00,0x07,0x3E,0x3D,0xE3,0xBD,0xC7,0xF8,0x03,0x87,0x1E,0xF1,0xFE,0x1F,0xC0,0x00,
0x00,0x07,0x0E,0x38,0xE3,0xBD,0xC7,0x00,0x03,0x87,0x0E,0xE1,0xC0,0x1C,0xE0,0x00,
0x00,0x07,0x0E,0x3F,0xE3,0xBD,0xC7,0x00,0x03,0x87,0x0E,0xE1,0xC0,0x1C,0xE0,0x00,
0x00,0x03,0x9E,0x7F,0xF3,0x99,0xC7,0x00,0x01,0xCE,0x07,0xC1,0xC0,0x1C,0x70,0x00,
0x00,0x03,0xFE,0x70,0x73,0x99,0xC7,0xFC,0x01,0xFE,0x07,0xC1,0xFF,0x1C,0x70,0x00,
0x00,0x00,0xF8,0xE0,0x3B,0x99,0xC7,0xFC,0x00,0x78,0x07,0xC1,0xFF,0x1C,0x38,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x02,0x93,0x93,0x05,0x38,0x39,0x82,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x02,0x92,0x12,0x05,0x20,0x19,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x03,0x90,0x92,0x05,0x08,0x29,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x13,0x93,0x07,0x38,0x3D,0x82,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x84,0x84,0x83,0x94,0xCC,0xE7,0x07,0x39,0xF8,0x3F,0x28,0x00,0x00,
0x00,0x00,0x16,0x96,0x96,0x82,0x14,0x88,0x95,0x84,0x25,0x68,0x2D,0x28,0x00,0x00,
0x00,0x00,0x1B,0x1B,0x1B,0x02,0x1C,0x88,0x94,0x84,0x25,0x08,0x21,0x38,0x00,0x00,
0x00,0x00,0x09,0x09,0x09,0x13,0x88,0xC8,0xE4,0xA7,0x39,0x09,0x21,0x10,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,
//Icon graphic data
rom char icon [8] = { 0x00,0x18,0x3C,0x7E,0x7E,0x3C,0x18,0x00};
// function prototype (every function must have a function prototype)
void init(void);
void lcd_read(char x, char y);
void lcd_clr(void);
void lcd_xy(unsigned char x,unsigned char y);
void d_graphic(char k);
void clr_graphic(void);
void d_icon(int x,int y);
void freespace(void);
void friction(void);
void box(void);
void calibrate(void);
unsigned int read_adc(char config);
// main function (main fucntion of the program)
void main(void)
//assign variable
unsigned char i=0,database;
unsigned char data[10];
unsigned int m,j;
init();
d_graphic(0); //display cytron logo
delay(300000); //delay for pic display
// display claibrating messages
send_config(0b00110000); //set to function set configuration
lcd_clr(); //clear the lcd
send_string(cali); //display string
lcd_goto (8); //cursor at 3rd character line
send_string(mssg1); //display string mssg1
lcd_goto(24); //cursor at 4th character line
send_string(mssg2); //display string mssg2
while(sw1); //wait for button pushed
while(!sw1); //wait for button release
calibrate(); //taking the current force as reference for flat plane
lcd_goto(1); //cursor at 3rd character, 1st character line
send_string(mssg3); //display string mssg3
lcd_goto(17); //cursor at 3rd character, 2st character line
send_string(mssg4); //display string mssg4
lcd_goto(0); //cursor at 1st character, 1st character line
send_char(0x10); //display symbol arrow
m =0 ; //set the variable 0
while(1) //loop forever
if (!sw1) //if sw1 is pressed, increase mode
while(!sw1); //wait until sw1 is release
m++; //increament m
if (m>1) m=0; //if m more than 1 , clear m
if (m==1) //if m is 1
lcd_goto(0); //cursor at 1st line
send_char(' '); //space 1st and 2nd character , 1st line
lcd_goto(16); //cursor at 2nd line
send_char(0x10); //display arrow at 2nd charater, 2nd line
else
send_char(0x10); //display arrow at 2nd charater, 1st line
send_char(' '); //space 1st and 2nd character , 2nd line
else if (!sw2) //if sw is pressed
while(!sw2); //wait until sw2 is released
lcd_clr(); //clear all character
clr_graphic(); //clear all graphic
// 16 bit timer initial status and start timer
TMR0H = 194; // value for timer reach overflow in 50 ms for clock 10MIPS
TMR0L = 246;
T0CONbits.TMR0ON = 1; //start timer
if (INTCONbits.TMR0IF==1) //if timer over flow ( occur every 50 ms) // to update data every 50 ms
INTCONbits.TMR0IF==0; //clear the flag bit
TMR0H=194; //value for timer reach overflow in 50 ms for clock 10MIPS
TMR0L=246;
if (m==1) friction(); //if mode is 1 , the do calculation friction, else do calculation freespace.
else freespace(); //update the data ( required for more accurate intergration ( faster, more accurate ))
i++; //increment variable i
if (i==10) //if i reach ten ( around 500 ms) update the icon position
if((x_dis/sens >60)||(x_dis/sens<-60)||(y_dis/sens>28)||(y_dis/sens<-28)) //if the icon position not in range of glcd
{ //mean 'the ball drop out from glcd'
d_graphic(1); //display graphic
delay(300000); //dealy for display the graphic
d_graphic(2); //display another graphic
delay(300000);
while(1);
d_icon(60-(x_dis/sens),28+(y_dis/sens)); //display icon at updated x,y position
i=0; //clear the variable i
//initialization
void init()
//set I/O input output
TRISD = 0b00000000; //configure PORTB I/O direction
TRISC = 0b00000000; //configure PORTC I/O direction
TRISB = 0b00000011;
TRISA = 0b00111111; //configure PORTA I/O direction
// ADC configuration
ADCON1 = 0b11000011; //set all portA as Analog Input, right justified
//Timer 0 configuration
T0CON = 0b00000100; //prescale 1: 32
// setup for pwm //For controlling back light
PR2 = 255;
T2CON = 0b00000100; //prescale 1:
CCP1CON = 0b00001100; //Configuration for pwm
CCP2CON = 0b00001100;
//configure lcd
rst = 0;
rst = 1;
delay (100000);
psb = 1;
//basic instruction config
send_config(0b00110000); //function set
lcd_clr(); //clear display at lcd
send_config(0b00000010); //lcd return to home
send_config(0b00001100); //display on, cursor off and cursor blink off
//set initial condition
send_config(0b00110100); //extended function set
send_config(0b00000100);
lcd_clr(); //clear lcd
CCPR1L = 50; //set the brightness of the back lcd
// functions
void beep(void) //short beep function
buzzer=1; //on buzzer
delay(10000); //short delay
buzzer=0; //off buzzer
//calculation for freespace
xaxis=read_adc(channel0); //read the force acting on x axis
yaxis=read_adc(channel1); //reat the force acting on y axis
xaxis-=x_off; //offset with value obtain before game start
yaxis-=y_off; //offset with value obtain before game start
if (((last_x-xaxis)==1)||((xaxis-last_x)==1)) xaxis=0; //filter noise
if (((last_y-yaxis)==1)||((last_y-yaxis)==-1)) yaxis=0; //filter noise
x_velo+=xaxis/2; //intergrate the force resultance velocity
y_velo+=yaxis/2; //intergrate the force resultance velocity
x_dis+=x_velo; //intergrate the velocity resultance distance
y_dis+=y_velo; //intergrate the velocity resultance distance
//calculation for constant friction (
void friction(void)
if(x_velo>0) x_velo--; //decreace the velocity ( making like having friction force )
else if (x_velo<0) x_velo++;
if(y_velo>0) y_velo--;
else if (y_velo<0) y_velo++;
x_dis += x_velo; //intergrate the velocity resultance distance
y_dis += y_velo; //intergrate the velocity resultance distance
// ADC function
unsigned short i;
unsigned long result ,result_temp=0;
ADCON0 = config;
delay(1000); // delay after changing configuration
for(i=20;i>0;i-=1) //looping 200 times for getting average value
ADCON0bits.GO = 1; //ADGO is the bit 2 of the ADCON0 register
while(ADCON0bits.GO==1); //ADC start, ADGO=0 after finish ADC progress
result=ADRESH;
result=result<<8; //shift to left for 8 bit
result=result|ADRESL; //10 bit result from ADC
result_temp+=result;
result = result_temp/20; //getting average value
ADCON0bits.ADON = 0; //adc module is shut off
return result;
x_off = read_adc(channel0); //read x_axis accelero value and save as offset
y_off = read_adc(channel1); //read x_axis accelero value and save as offset
z_off = read_adc(channel2); //read x_axis accelero value and save as offset
// LCD function
// Config function
void delay(unsigned long data) //delay function, the delay time
{ //depend on the given value
for( ;data>0;data-=1);
void send_config(unsigned char data) //send lcd configuration
rw=0; //set lcd to write mode
rs=0; //set lcd to configuration mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay(20);
e=0;
delay(20);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
delay(20);
e=0;
delay(20);
// char function (make sure is in basic function before use lcd function)
void lcd_goto(unsigned char data) //set the location of the lcd cursor
send_config(0x80+data);
// | |00|01|02|03|04|05|06|07| | //1 location can store 2 character
// | |17|18|19|...........|15| |
// | |09|10|11|...........|23| |
// | |24|.................|31| |
void lcd_clr(void) //clear the lcd
send_config(0x01);
delay(600);
void send_string(const char *s) //send a string to display in the lcd
unsigned char i=0;
void function( char data) //1 for extention , 0 for basic * must off graphic before go back basic function
send_config(0x30 |data << 2);
// graphic function ( make sure in extention function before use grapchic funcion )
// CGRAM map for GLCD Display
// y x (column )
// row | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
// 0 0 |UB |LB | | | | | | | |
// 1 1 | | | | | | | | |
// 2 2 | | | | | | | | |
// 3 3 | | | | | | | | |
// 31 31 |_______|___|___|___|___|___|___|___|
// | 8 | 9 |10 |11 |12 |13 |14 |15 |
// 32 0 |UB |LB | | | | | | | |
// 33 1 | | | | | | | | |
// 34 2 | | | | | | | | |
// 35 3 | | | | | | | | |
// 63 31 | | | | | | | | |
// UB - upper byte , LB - lower byte
// To write an LB, UB must wrote first.
// display an icon at position x,y
void d_icon(int x,int y) //display first bit of 8x8 icon at x,y position
char i,j;
if (p_x%16 <8) //if x position is on upper byte of 16 bit
for (j=0;j<8;j++) //repeat for 8 vertical line
lcd_xy(p_x/16,(p_y+j)%64); //go to the location and y is re-adjust after adding j ( > 64 after adding j )
send_char(0); //send upperbyte with shifting according to the x position
send_char(0); //send lowerbyte with shifting according to the x position
else
for (j=0;j<8;j++)
send_char (0); //send dummy data to the upperbyte
send_char(0); //send lowerbyte data with shifting according to the x position
if(p_x/16 == 7) lcd_xy(0,p_y+j);
send_char(0); //send upperbyte of the next 'x' with shifting according to the x position
if (x%16 <8) //if x position is on upper byte of 16 bit
lcd_xy(x/16,(y+j)%64); //go to the location and y is re-adjust after adding j ( > 64 after adding j )
send_char(icon[j]>> x%8); //send upperbyte with shifting according to the x position
send_char(icon[j]<< (8-x%8)); //send lowerbyte with shifting according to the x position
else
for (j=0;j<8;j++)
send_char(icon[j]>> x%8); //send lowerbyte data with shifting according to the x position
if(x/16 == 7) lcd_xy(0,y+j);
send_char(icon[j]<< (8-x%8)); //send upperbyte of the next 'x' with shifting according to the x position
p_x = x; //save as previous location
p_y= y; //save as previous location
void lcd_xy(unsigned char x,unsigned char y) //set the xy position for graphic
if( y >= 32)
{ //if vertical more or equal 32
send_config(0x80+y-32); //adjust the vertical line
send_config(0x80+x+8); //for more detail refer GDRAM in user manual
else
send_config(0x80+y); //vertical (Y) max 63
send_config(0x80+x); //horizontal (X) max 8 (horizontal is divided by 16 bit data (represented in 2 bytes))
// display the picture according to the data array defined
unsigned int i,j,y;
send_config(0b00111100); //set to extention mode nad graphic off
y = 0b10000000; //set y as vertical configuration
for(j = 0; j <32 ; j++) //32 line
send_config(y++); //increase line
send_config(0b10000000); //set add back to 0
for(i=0;i<16;i++)send_char(graphic[k][i+j*16]); //display first half
for(i=0;i<16;i++)send_char(graphic[k][i+512+j*16]); //display second half **since the x add is increased more than 7. See CGRAM map above or refer user manual for CGRAM map for more detail.
send_config(0b00111110); //set to extention mode and graphic on
// clear all the graphic
void clr_graphic()
unsigned int i,j,y;
send_config (0b00111100); //set to extention mode and graphic off
for(i=0;i<32;i++)send_char(0); //clear all
