16 segment display decoder
Postby azry » Sun Nov 14, 2010 8:48 pm
Hi, would like to ask is there a decoder ic to display alphabets on a 16 segment display?
If a 7 segment display uses the 7447 decoder ic to display numbers, then what about a 16 segment display?
Is there such ic that can output alphabet based on a 5 or 6 bit input like the 7447 decoder?
Tried googling around but to no avail. Hope any experts here can enlighten me on this.
Thank You
azry
Re: 16 segment display decoder
Postby ABSF » Mon Nov 15, 2010 3:06 pm
I have a microprocessor board using this type of 16-segment display. But it was in a 20-characters flouresene flat tube. AFAIK it deosn't have a decoder in it but it used the onboard uprocessor's ports to turn on and off each segment using multiplexing method. I can't find the board now. Don't know where I chat it. But I still remember the uprocessor is a 65C02 variant.
Even you can find the decoder, it would be very expansive as not many of them were being produced. Why not use a PIC with 2*8 ports or 2 pc eproms and cascade them together as a 16-bit eprom to act as a decoder. I do have 16 bits wide eprom but you must have the means to program it.
Postby azry » Tue Nov 16, 2010 3:47 pm
ABSF WROTE:I have a microprocessor board using this type of 16-segment display. But it was in a 20-characters flouresene flat tube. AFAIK it deosn't have a decoder in it but it used the onboard uprocessor's ports to turn on and off each segment using multiplexing method. I can't find the board now. Don't know where I chat it. But I still remember the uprocessor is a 65C02 variant.
Actually its for my project. Initial plan was to use pic as the decoder, just wondering if I can save some ports at the pic to connect other peripheral devices.
So now I have tabulate the output for each alphabet and program that into the pic correct?
Thanks Allen for that information!
Have a nice Day!
azry
Postby ober » Thu Nov 18, 2010 11:14 am
Yes, we seldom see, or should I say never see decoder for 16 segment display. Might be because is too rarely used. Anyway, as ABSF said, a microcontroller with enough IO should be easily be programmed as the decoder.
Postby shahrul » Thu Nov 18, 2010 4:14 pm
Maybe you might use TLC5940. That's 16 Channel LED Driver using SPI.
Postby ober » Fri Nov 19, 2010 11:11 pm
shahrul WROTE:Maybe you might use TLC5940. That's 16 Channel LED Driver using SPI.
Shahrul, you use that chip before? Seem to be powerful chip... 16 channels of PWM?
Postby shahrul » Tue Nov 23, 2010 9:31 pm
I have buy this chip, still try to program. It price >RM10/unit
Postby yonghui » Wed Nov 24, 2010 9:09 am
i saw microchip new PIC16F1 series got segmental LCD driver.example, try seek for 16F193X . it has up to 16/ 24 segment pins for driving the LCD.
Postby ABSF » Sat Nov 27, 2010 11:55 pm
Come to think about your problem again, using a PIC say 16F877a to decode will use up 16 port pins for the segments. And if you have 8 characters (you didn't say how many char in your display), another 8 port pins for the characters. So what's left in your 16f877a will be limited for you to use.
One way to do it is a two PIC solution. One for your main program and another sorely for decoding only. The decoder will take 8 data inputs from the main PIC.
Of course there is another way to do it and it is to use a 16 segment driver with serial inputs (I2C or SPI) like MAX6969. There was a discussion (2008) of this chip here:
http://www.electro-tech-online.com/micr ... ver-2.html
The datasheet of MAX6969 is here:
http://datasheets.maxim-ic.com/en/ds/MAX6969.pdf
And you can get the chip here in PDIP 24 pin package here:
http://search.digikey.com/scripts/DkSea ... 9ANG%2B-ND
USD 8.87 + postage is not too bad. Or you can try to write to MAXIM asking for a free sample. I did it last time and they did sent me the free sample but in SMT package :roll:
Best of lock with your project and cheers
Postby ober » Sun Nov 28, 2010 5:44 pm
Maybe a latch could be helpful and easier to save more IO?
Use 74HC573, very cheap latch, 8 output latch. You might need 2 of these, still consider very cheap solution.
