Hello,
if i use the 12 v, 2A adapter then i use L293D to stepper motor(rated 1.2A). will the L293D burn?
donny WROTE:Hello,
donny WROTE:some of my friend say it will but i need confirmation before i build the circuit..
anyone out there would like to share?The L293D spec. is 600mA.. thanks allen for you answer.
donny WROTE:i see. the L293D will not sustain the 2A supply but the stepper motor can right?
If I have a DC motor rated at 12V, 1A max. And a power supply that can source 12V 2A. Can I connect the DC motor to that power supply directly in no load condition?
donny WROTE:ok.i understand already.Thanks.
all is depends on the load.since the load is rated 1.2A, therefore the motor driver should also support 1.2A.Am i right?
