Logic gate MOSFET - IRL520
Postby mtaufiq23 » Sat Nov 26, 2011 9:07 pm
hi guys...
where could i find the mosfet IRL520 in area around skudai, johor...
if not possible where the nearest place i can purchase this??
mtaufiq23
Re: Logic gate MOSFET - IRL520
Postby ABSF » Sun Nov 27, 2011 7:18 am
The datasheet says the Vgs of IRL520 is +/- 10V while IRF520 is +/-20V. You might try with IRF520 (easy to get) and see if additional level shifter is required.
If not working you can get it here
http://my.element14.com/jsp/search/brow ... allpartial
Postby zhenning » Sun Nov 27, 2011 9:36 pm
rs malaysia has them also. http://malaysia.rs-online.com/web/c/?sr ... 0&x=13&y=7 as long as you order online, the shipping fees is waived. =)
zhenning
Postby kl84 » Mon Nov 28, 2011 8:52 pm
You must use IRL520? What about IRFZ48N? Usually I use it to drive motor. Although the VDSS is only 55V compared to 100V for IRF520, the RDS(ON) is much much lower at only 14mOhm. The lower the better so that the mosfet dissipates little power. Of course there are more parameters that you need to look into before you choose this IRFZ48N...it's just a suggestion if you can't get IRL520 easily.
kl84
Postby ABSF » Tue Nov 29, 2011 9:36 am
kl84 WROTE:You must use IRL520? What about IRFZ48N? Usually I use it to drive motor. Although the VDSS is only 55V compared to 100V for IRF520, the RDS(ON) is much much lower at only 14mOhm. The lower the better so that the mosfet dissipates little power. Of course there are more parameters that you need to look into before you choose this IRFZ48N...it's just a suggestion if you can't get IRL520 easily.
The difference between IRL520 with IRF520 and IRFZ48N is not the Rds(on). it is the Vgs(th) . IRL520 is a logic-gate level MOSFET and it can turn ON and OFF within logic level of 0-5V. If you see the datasheet IRL520 has Vgs(th) of 1-2V while IRFZ48N is 2-4V. What I read from another forum is that Vgs(th) is the voltage between Gate and Source when the MOSFET begins to conduct but not saturate. That is not good for the MOSFET to be used as a switch because 2-4V is at its linear part of its curve where Rds(on) is not at its minimum.
You can read the details from here
http://arduino.cc/forum/index.php?topic=49993.0
Postby robosang » Fri Dec 02, 2011 6:36 pm
Allen, betul tu 8-)
