LCD 40X2 + SK40C
LCD 40X2 + SK40C
Postby nik_kktm » Thu Dec 08, 2011 11:55 pm
Hi....i try to used the 40X2 LCD with SK40C...but the backlight not working because the polarity of the backlight din fit with SK40C (VDD & B/L). So i tried change it with cable connection.........it works but the regulator at SK40C became HOT. What's the problem???? tHANKS..... :roll:
nik_kktm
Re: LCD 40X2 + SK40C
Postby ABSF » Fri Dec 09, 2011 6:52 am
nik_kktm WROTE:Hi....i try to used the 40X2 LCD with SK40C...but the backlight not working because the polarity of the backlight din fit with SK40C (VDD & B/L). So i tried change it with cable connection.........it works but the regulator at SK40C became HOT. What's the problem???? tHANKS..... :roll:
Change R8 10ohm to a higher value to reduce current to the backlite should slove the problem. I'll try 50 ohm as a start.
Postby nik_kktm » Fri Dec 09, 2011 1:35 pm
hi...Thanks for reply......it R8 at back of the LCD right? or at SK40C?? :)
nik_kktm
Postby ABSF » Fri Dec 09, 2011 2:07 pm
Oops, it is right under the 40 pin ic socket on the RHS. And worst is it is a SMD resistor. One way you can do is put another resistor in series with it on JP8 (LCD B/L). Just remove the jumper and solder another resistor of 33 ohm across it.
Look at P5 and P45 of the SK-40C user manual.SK40C
Postby nik_kktm » Sat Dec 10, 2011 12:18 pm
Haaa thanks a lot Allen.... :D already done thanks for helping. ;)
nik_kktm
