UART Fingerprint Reader
Postby mashitah » Sat Feb 23, 2013 2:24 pm
i want to ask about my uart fingerprint. i try to connect the fingerprint module with usb-uart converter to my laptop.. unfortunately, when i open the gui and click open port, the gui hang and cannot do anything. i dont know why.. i have try so many times but still same.. i try use the Fingerprint Time Attendance Application gui and also Fingerprint Reader GUI but still have the same problem.. the default baud rate at the gui is 19600..
i also try to change the baud rate at the port at device manager to 19600 and also default 9600 but also cannot work..
what should actually to make this device working properly??
mashitah
Re: UART Fingerprint Reader
Postby robosang » Sat Feb 23, 2013 2:31 pm
Are you sure is 19600? I thought it should be 19200 :twisted:
Postby mashitah » Sat Feb 23, 2013 2:33 pm
the blue light from the fingerprint module also not on.. but why?? not enough power?? but i put 5v to the vcc
mashitah
Postby mashitah » Sat Feb 23, 2013 2:36 pm
sory typing error 19200.. this default thing.. just choose.. :geek:
mashitah
Postby robosang » Sat Feb 23, 2013 4:43 pm
a photo of the hardware would be helpful
Postby yonghui » Mon Feb 25, 2013 10:15 am
have u try to put it on other computer?
Postby gadgetng » Wed Feb 27, 2013 2:23 pm
It should be the connection/wiring from PC to the fingerprint reader. Pls double check/confirm.
gadgetng
