DS-LCD-082A aka LCD8x2 any sample code pic32MX
Re: DS-LCD-082A aka LCD8x2 any sample code pic32MX
Postby bengchet » Mon Nov 16, 2015 10:25 am
Driver? Bukan ade library ke? Apa IDE you guna utk program pic32Mx?
Postby Nurul.Syuhada » Mon Nov 16, 2015 10:45 am
Hi, You can refer here for PIC32mx with the LCD and it is for MPLAB IDE. If you are using Pinguino IDE, you can use the example code provided in the library named "display" and change the pin number in the example code. Thanks.
Nurul.Syuhada
Postby ZaM » Mon Nov 16, 2015 4:45 pm
hi, after google, maybe this can help you. http://hades.mech.northwestern.edu/inde ... rallel_LCD. But maybe you can try this. http://mytechinvention.blogspot.my/2013 ... erial.html and http://shahrulnizam.com/skpic32-sebagai-chipkit-max32/ chipKIT MAX32 is one of arduino compatible that use PIC32 as controller. take note, LCD 8x2 command same as 16x2 or 20x4.
ZaM
Postby ZaM » Mon Nov 16, 2015 5:19 pm
haha. sorry, wrong PIC model. maybe you can try this code. i use in one of my project. use mplab x with pic PIC32MX220F032B and xc32 compiler
SK1632.X.rar
(43.58 KiB) Downloaded 1342 times
ZaM
