Re: DS-LCD-082A aka LCD8x2 any sample code pic32MX
Posted: Mon Nov 16, 2015 10:25 am
by bengchet
Driver? Bukan ade library ke? Apa IDE you guna utk program pic32Mx?
Posted: Mon Nov 16, 2015 10:45 am
by Nurul.Syuhada
Hi, You can refer here for PIC32mx with the LCD and it is for MPLAB IDE. If you are using Pinguino IDE, you can use the example code provided in the library named "display" and change the pin number in the example code. Thanks.
