sensors
sensors
Postby captenusop » Thu Oct 07, 2010 8:46 am
hy..
is LSS05-Line Sensor suitable for robocon.. :mrgreen:
captenusop
Re: sensors
Postby hyng » Thu Oct 07, 2010 1:32 pm
If you go for low cost and easy to use solution, this is suitable for you. But this sensor sensitivity may effect by the lighting inside the ROBOCON games. You have to test it.
Re: sensors
Postby yonghui » Thu Oct 07, 2010 7:26 pm
LSS05 is intended for simple project. the suitability of it for robocon will need to be tested. the sensing range of LSS05 is also limited to 1 to mayb 3 cm range. the output from LSS05 is digital.
Re: sensors
Postby captenusop » Fri Oct 08, 2010 8:13 am
:o ,, tq for your answer..
so what is suitable for robocon "SICK Digital Fiber Sensor" @ "SUNX Digital Fiber Sensor" @ any else suggestion?
captenusop
Re: sensors
Postby sich » Fri Oct 08, 2010 1:08 pm
Both SICK & SUNX are suitable...i personally never heard of any complain yet.
Re: sensors
Postby captenusop » Fri Oct 08, 2010 3:10 pm
:P
tq
captenusop
