Current Sense Breakout Board ACS712
Postby syafiq hashim » Wed Dec 21, 2011 12:23 am
Product Code : SN-ACS712
can this sensor sense current up to 60A?
is the output can be deliver directly into PIC 16F877A?
my project require to sense current directly at power distribution board (single phase building). so the AC current as the input will be sense by this sensor, and the output of the sensor will be deliver into PIC.
syafiq hashim
Re: Current Sense Breakout Board ACS712
Postby shahrul » Wed Dec 21, 2011 1:14 am
ACS712 zero crossing at 2.5V. Output sensitivity is 66 to 185 mV/A. I not see the maximum output voltage of this sensor.
Assume it can goes from 0-5V, take the one 66mV/A, so 2.5V / 66mV/A = 37A. But I think it can't measure up to 37A.
Suggestion, you can use current transformer SCT-013, can measure up to 100A. You can find at ebay.
Postby ABSF » Wed Dec 21, 2011 7:35 am
The bigger cousins of ACS712 can go up to +/- 100A. The sensitivity is 20mV/A. Take a look at their datasheet here.
Allegro MicroSystems - ACS758 Thermally Enhanced, Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 100 µΩ Current Conductor
http://www.allegromicro.com/Products/Cu ... CS758.aspx
Allegro MicroSystems - 50 to 200 A Integrated Conductor Sensor ICs
http://www.allegromicro.com/en/Products ... r-ICs.aspx
They do offer samples and you can try writing to them as a Uni student. I once wrote them on behalf of my company and they did give me 1 or 2 pieces for experiments.
Postby ABSF » Wed Dec 21, 2011 8:59 am
shahrul WROTE:Suggestion, you can use current transformer SCT-013, can measure up to 100A. You can find at ebay.
I checked with eBay for this item. Very well designed and dont have to break the AC connections. Unfortunately, all the sellers dont ship the item to Malaysia. May be has something to do with stealing electricity from Tenaga Malaysia that all addon to power lines are illegal and not allowed.
Postby shahrul » Wed Dec 21, 2011 10:03 am
ABSF WROTE:I checked with eBay for this item. Very well designed and dont have to break the AC connections. Unfortunately, all the sellers dont ship the item to Malaysia. May be has something to do with stealing electricity from Tenaga Malaysia that all addon to power lines are illegal and not allowed.
I already have one SCT-013. My friend bought this.
I'm not use this because my previous project just detect small AC current <10A.
Postby ABSF » Fri Dec 23, 2011 4:11 pm
shahrul WROTE:I already have one SCT-013. My friend bought this.
ah.... :o so there's no problem for syafiq to get one from eBay HK. I might need one some day too... :)
