What kind of sensor to use ?
Postby lts2692 » Wed Jun 12, 2013 12:54 am
Hi guys, i've assigned to build a sensor device that could detect the obstacles as the signal getting weaker when it meets obstacles. Other than that it may differentiate the density/thickness of obstacles.
What kind of appropriate sensor should i use ? IR / RF transmitter / ultrasonic sensor / etc.
Please advice. Thanks
lts2692
Re: What kind of sensor to use ?
Postby robosang » Sat Jun 15, 2013 6:48 am
Test it and you will know.
Postby shahrul » Sun Jun 16, 2013 10:05 pm
You must think logic. RF is tranmit/receive data, can't measure object distance. IR can measure distance, but maybe to short distance and only provide HIGH/LOW output. Ultrasonic can measures distance but can't know thickness. For thickness maybe need a camera.
