[SOLVED] SN-LLS Liquid Level Sensor
Re: [SOLVED] SN-LLS Liquid Level Sensor
Postby robosang » Mon Dec 03, 2012 3:30 pm
From the result you get and the calculation, you are doing the wrong assumption, wrong calculation. Who say the Rref is 1500? Did you measure it?
Postby wstay » Mon Dec 03, 2012 6:22 pm
robosang;
from the datasheet
it saying the Reference resistance is 1500 +/- 10%
same with the Sensor Resistance when empty 1500 +/- 10% ;
From the simple voltage divider rule;I connect the Sensor resistance at bottom and the reference resistance at the top.
when i measuring the resistance; it is about 1600 Ohm
wstay
Postby robosang » Mon Dec 03, 2012 9:09 pm
OK, good!
1600 Ohm is Rref or Rsense? Try measuring both when there is no water/liquid and it is full.
Postby wstay » Wed Dec 05, 2012 12:30 am
I think the etape sensor is faulty;
I cannot get any reading when measuring the resistance across Pin 2 and Pin 3; pin 1 and Pin 4.
I think i need to claim it.
Can I just ignore the reference resistor ? and i just connect the Sensor resistance?
wstay
Postby robosang » Wed Dec 05, 2012 7:26 am
I don know whether yo can claim or not, I am not Cytron.
You can try fill in the support form under support tab, their technical team might be able to help.
BTW, you can ignore the Rref, although I do not have the sensor, but from the diagram, you can do that. Also if you are getting changes on voltage, the sensor is working.
