Maxbotic Ultrasonic sensor how to control?
Re: Maxbotic Ultrasonic sensor how to control?
Postby robosang » Sat Nov 07, 2009 2:22 pm
Hahah! Finally is working? I din go through the code, but hopefully other that use Ultrasonic through PWM can benefit from your code :shock:
Postby Light » Sun Feb 21, 2010 9:25 pm
thanks a lot for sharing your experience with others.
Im using MikroC PRO for compiling source codes...well..i have a problem when i tried to compile your code, the errors below occurs:
can't open include file #include <pic.h>
can't open include file #include <stdlib.h>
can't open include file #include <string.h>
can't open include file #include <stdio.h>
can't open include file #include "delay.h"
can't open include file #include "delay.c"
do i have to add those .H files into 'include' directory? if yes, can you please upload it here because i tried searching for them and i keep finding different results where i dont know which one is the correct one.
i have more questions about the source code (since im weak in programing) but i want to compile the code successfully first.
thank you
Light
Postby luqman hakim » Mon Feb 22, 2010 9:29 am
hi shao.. tq for you sharing about the code... i`m using MicroChip MPLAB IDE v8.43 to compile your last post source code that you said had been success.. but fail.. i don`t where is the error in your source code
i also have more questions about the source code (since i`m weak in programing) but prefer to compile the code successfully first...
luqman hakim
Postby luqman hakim » Mon Feb 22, 2010 9:58 am
can't open include file "delay.h": No such file or directory..
this is error that i found..
luqman hakim
Postby sich » Mon Feb 22, 2010 3:01 pm
Light WROTE:thanks a lot for sharing your experience with others.
I think Shao modified PR23's source code so you can find the .h files in PR23 sample code provided in Cytron website.
Light WROTE:Im using MikroC PRO for compiling source codes...well..i have a problem when i tried to compile your code, the errors below occurs:
Since you're using MikroC, you may find syntax errors when you compile this source code directly without modify it. It's written for Hitech C compiler i guess.
luqman hakim WROTE:can't open include file "delay.h": No such file or directory..
Same thing goes to luqman hakin too. You need to include the .h files.
Postby luqman hakim » Mon Feb 22, 2010 9:42 pm
did u mean that i have to wrote like this
#include <delay.h>
but still error like this..
luqman hakim
Postby sich » Tue Feb 23, 2010 4:27 pm
Adding #include <delay.h> in your program means you want the program to find delay.h where some of your functions called are declared. If that's the case, where's your delay.h file? So your problem may be solved by copy the file and place it in the same folder as your main program. Now where to get the file? I think it's created by Cytron for PR23 and other products. You can have a try to download it from PR23's product page. Another way is ask Shao to confirm the source.
Postby Light » Mon Mar 08, 2010 10:24 pm
hi again
i tried compiling the code in HI-TECH C Compiler....it wont work unless i delete the following lines:
#include "delay.h"
#include "delay.c"
DelayMs(250); //sensor module power up time
means if i delete these files the code will be compiled successfully...anyway these lines r not important in this code...but what if i need to use Delay later on ? thats why im asking what's the problem.
the other question is....in the following equation:
distance=value*1.75616; // calculate inch value per inch = 147us with 20Mhz internal clock.
how the number 1.75616 have being calculated ? the datasheet mentions that 147us is the pulse width..thats all.
tq
Light
Postby luqman hakim » Mon Mar 08, 2010 10:49 pm
hi light...
try cpoy, paste.. compile in MPLAB software
#define   PIC_CLK 20000000 //change this to 3.6864, 4, 16 or 20MHz
//   Include
#include <pic.h>
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include "delay.h"
#include "delay.c"
//   Configuration
__CONFIG ( 0x3F32 );
//   Function Prototype
void ultrasonic(void);   // Find range based on input
void init(void);
void rangecal(void);
//   global variable
unsigned int To=0;
unsigned int TH=0;
unsigned int value;
unsigned int distance;
unsigned int data=0;
//   interrupt prototype
   if(TMR0IF)         // TMR0 is overflow
      TMR0IF=0;    // clear flag bit
      To+=0x100;      // count number of TMR0 overflow ( make it to 16bit TMR)
//   Main Function
void main(void)
   init();
   ultrasonic();
// Initailization
// Description : Initialize the microcontroller
void init()
   // Tris configuration (input or output)
   TRISA = 0b00000000;      //set PORTA as output
   TRISB = 0b00000100;      //set RB2 pin as input, other as output
   TRISC = 0b00000000;      //set PORTA as output
   RB4=1;   //5V to sensor
   // TMR 0 configuation
   T0CS=0;
   PSA=0;
   PS2=1;                  // prescale 1:256
   PS1=1;                  //
   PS0=1;                  //
   TMR0IE=1;                  // TMR0 Interrupt
   TMR0=0;
   GIE = 1;   //global interrupt
// FUNCTIONS
//Calculate the range from the sensor depending on PWM signal input
      if(RB2==0)               //if RB2 is high
      TMR0=0;            // clear all counter involved, start new count for period of RB2 high
      To=0;
      else
      TH=TMR0+To;         // RB2 is 0 mean is falling from 1 save TH, RB2 high period
      value=TH;      //value of tmr0+to
      rangecal();
void rangecal(void)
      if(distance>100)
      PORTC=0B00000001;
      else if(distance>80)
      PORTC=0B00000010;
      else if(distance>60)
      PORTC=0B00000100;
      else if(distance>40)
      PORTC=0B00001000;
      else if(distance>20)
      PORTC=0B00010000;
at first, the code it will looks like this to success... build successfully..
then..
create one text file...
KeyGhost
Designed by Shane Tolmie Apr 99.
Microprocessor: see mainkg.c
Compiled with:   see mainkg.c
Overall goal:    Delay Routines
#ifndef __DELAY_C
#define __DELAY_C
#include   "always.h"
#include   "delay.h"
void DelayBigUs(unsigned int cnt)
   unsigned char   i;
   i = (unsigned char)(cnt>>8);
   while(i>=1)
      i--;
      DelayUs(253);
      CLRWDT();
   DelayUs((unsigned char)(cnt & 0xFF));
void DelayMs(unsigned char cnt)
   unsigned char   i;
   do {
      i = 4;
      do {
         DelayUs(250);
         CLRWDT();
      } while(--i);
   } while(--cnt);
//this copy is for the interrupt function
void DelayMs_interrupt(unsigned char cnt)
   unsigned char   i;
   do {
      i = 4;
      do {
         DelayUs(250);
      } while(--i);
   } while(--cnt);
void DelayBigMs(unsigned int cnt)
   unsigned char   i;
   do {
      i = 4;
      do {
         DelayUs(250);
         CLRWDT();
      } while(--i);
   } while(--cnt);
void DelayS(unsigned char cnt)
   unsigned char i;
   do {
      i = 4;
      do {
         DelayMs(250);
         CLRWDT();
      } while(--i);
   } while(--cnt);
#endif
then save as delay.txt
after that copy this file in the folder in your project.. try it..!
luqman hakim
Postby ober » Mon Mar 08, 2010 10:56 pm
Light WROTE:hi again
#include "delay.h"
#include "delay.c"
Normally if you include library or function from other files, we include the header file only, not the c file. So in your case, it should be:
#include "delay.h" only.
However, using "xxxx.h" mean the file is in the compiler library where it will automatically search the file. If you use <xxxx.h> mean the file is in the same folder as your program C file, or project folder.
tq
You need to understand the relationship between value and timing. What is the value represent? How do it obtain the value? from Timer0, what is the prescaler? What does 1 or 2 or 3 and so on represent? I think PR23 did explain the ultrasonic (using PWM) in detail, you can start from there. Anyway I do not sure where you get the formula from, you need to really check with the source that wrote this code.
PreviousNext
