adc value for IMU
i'm testing IMU for static condition,,
means the value when the board is in flat surface/not moving
currently measuring raw value from adc for x & y axis...
this is what i do..
but the value moved a lot,, it is not static at all, also the range quite big
it can be 100++ to full masurement 1023....
how can get the value?
- CODE: SELECT_ALL_CODE
float accelero_x()
set_ADC_channel(0);
delay_us(20);
return read_adc();
float accelero_y()
set_ADC_channel(5);
delay_us(20);
return read_adc();
this is what i do..
