5- IMU interfacing, multiplexer
Postby Chlorine » Mon Mar 08, 2010 12:03 am
Sorry for the inconvenient..
I need to know how to interface 5-IMU sensor
Chlorine
Re: 5- IMU interfacing, multiplexer
Postby ober » Mon Mar 08, 2010 4:05 pm
5 degree IMU. If you are referring to the product of Cytron, it provide analog output (in voltage) from on board Accelerometer and Gyro. Basically, you connect to microcontroller ADC input (analog input). If there are 5 analog output, then you require 5 analog input at microcontroller.
Postby Chlorine » Tue Mar 09, 2010 12:05 am
Basically if i'm using a ADC in a pic with 10 channel.
Does the vref for both 5 analogous input is the same?
Chlorine
Postby ober » Tue Mar 09, 2010 2:34 pm
It should be the same.
