Setting up the oscilloscope to read accelerometer output
Postby dareck322 » Sat May 29, 2010 12:03 pm
Hi there. Does anyone know how to set up the oscilloscope to read the output from the ADXL335 accelerometer? I've been trying to get the following output reading format shown here:
http://www.youtube.com/watch?v=Z2ZLf4_3 ... r_embedded
Thanks in advance for any help given =)
dareck322
Re: Setting up the oscilloscope to read accelerometer output
Postby ober » Sat May 29, 2010 12:57 pm
You say you have been trying? So what is the output and what is the part you needed help?
Postby dareck322 » Mon May 31, 2010 9:23 am
At the moment, I've only been able to see the level changes of the accelerometer due to tilting. Example: a roll to the left in the Y-axis would provide an approx. 1.2V output.
And I would only be able to see the whole level of the voltage move upwards or downward due to left and right motions in the Y-axis. I am unable to produce a sort of sine wave-like output as shown in the youtube link
dareck322
Postby waiweng83 » Mon May 31, 2010 12:02 pm
Increase the time scale of your oscilloscope to around 0.5 - 1 second.
waiweng83
