heart beat human
Wed Sep 15, 2010 4:13 pm
by luq1988
what kind of sensor is used to detect heart beat human??
Re: heart beat human
Thu Sep 16, 2010 10:49 am
by yonghui
i got heard of using Infrared sensors, try to search for it
Thu Sep 23, 2010 11:33 pm
by luq1988
tq for the info..
Sat Sep 25, 2010 9:19 pm
by anhingus
withe an infrared transmitter/receiver pair feeding a 741 opamp or whatever. shape the input with a schmitt trigger for pulse counting.
as i recall, this rig is called a pulse plethysmometer.
since this works on reflected infrared, sticking a finger between source and receiver does not do well. try mounting the ir pair at 90 degrees.
the infrared beam ends up modulated by the expansion and contraction of blood vessels due to heartbeat.
you could also use a microphone or a small speaker and go by sound or possibly a flex sensor or ultrasound or . . . lots of possibilities.
Sun Sep 26, 2010 10:56 am
by ober
You could also try to take a look at this, the
Polar Heart Rate Monitor from Sparkfun. Might be suitable for your requirement.
Wed Oct 13, 2010 2:09 am
by lordtct
or, you could use a piezoelectric transducer + op-amp arrangement
Sun Oct 17, 2010 3:21 am
by happyrush
Hi there ,
You are playing ECG?Heart beat can measure from finger as well.Here is the full project,if you want,you can follow the link:http://www.stm32circle.com/projects/project.php?id=31
No sensor require, just TWO copper plate.
