flexiforce sensor - please help me
Hi
I tried to calibrate the flexiforce sensor but i couldn't get a linear conductance graph although I followed all the steps provided in the user manual http://www.cytron.com.my/datasheet/sens ... Manual.pdf .
Furthermore, it does not gives stable reading when I conditioned/calibrated it. The resistance value kept on decreasing although if I waited for 3 minutes. Besides it also didn't give the same reading although the same amount of weight placed on it.
What should I do? Does this means the sensor has broken/damaged?
Thanks
Thanks
