medium range ir sensor
Postby fatimah » Sat Nov 06, 2010 12:24 pm
i want to ask...since this device has 3 terminal, vcc, ground and signal....i just to highlight signal terminal....is it the output of this terminal analog or digital....in manual doesn't state it....
fatimah
Re: medium range ir sensor
Postby yonghui » Sat Nov 06, 2010 2:31 pm
IR01A, medium range Infrared sensor is digital. its giving 1 and 0 only. the threshold for 1 or 0 is adjusted using the preset on the sensor. its obstacle sensor, which sense the present and absent of things in front it.
Postby fatimah » Fri Nov 12, 2010 7:38 pm
can i declared it as a push button in order to programm it?
fatimah
Postby ober » Fri Nov 12, 2010 8:43 pm
fatimah WROTE:can i declared it as a push button in order to programm it?
Declare in what method? Just label or assign pin for it?
As long as it is digital input, you can assign any label for it.
Postby fatimah » Thu Dec 30, 2010 12:41 pm
for connection process, do u have a safety ways to make a connection of ir sensor to SK40C, means that it we just simply connect by using simple wire or need to used connector at ir sensor, then,used wire?do u have a better suggestion? just ask ur opinion....coz i heard that device very sensitive
fatimah
Postby yonghui » Thu Dec 30, 2010 4:21 pm
it needs simple connection only direct connection is possible if its connected to 5V microcontroller.
if u really wan protection, u can connect resistors on the signal pin of the sensor.
