by arisu1love » Tue May 10, 2011 1:06 pm
Thank you for your replies. The default mode is retrigger mode, so I did not change that too, because it is soldered with wire into place, I did not tamper with it. I find it gives a 010100010101 output (i use to light led for testing) when there is motion. Not quite what I expected because I expected 11111111 when there is occupant. The delay time setting which is available on the sensor, may i know what is the purpose of it, and how exactly to tune it to suit my application? My application is for home automation where devices are turned on/off with when occupants are present/not present.
