need your opinions to choose sensor
Postby eklim » Mon Sep 26, 2011 11:41 pm
what the suitable sensor or component to use in detect the wire cut? In the case, i need to detect the location when 1 wire (telecom wire) is cut and this component/ sensor need to send the data to the pic controller. Pls advice, thanks.
eklim
Re: need your opinions to choose sensor
Postby ober » Tue Sep 27, 2011 9:27 am
Well, I am not familiar with this detection or application, but you might be able to search for some information by googling TDR.
TDR stand for Time Domain Reflectometry, and the device to perform this task is also call TDR - Time Domain Reflectometer.
Good luck
Postby robosang » Thu Sep 29, 2011 9:33 pm
TDR..... quite advance method to use!
Postby low5545 » Tue Oct 25, 2011 4:25 pm
If you just want to detect wire cut, just create a circuit like the picture below and check the output (HIGH or LOW)
low5545
