need your opinions
need your opinions
Postby eklim » Mon Sep 26, 2011 11:42 pm
what the suitable sensor or component to use in detect the wire cut? In the case, i need to detect the location when 1 wire (telecom wire) is cut and this component/ sensor need to send the data to the pic controller. Pls advice, thanks.
eklim
Re: need your opinions
Postby yonghui » Mon Sep 26, 2011 11:57 pm
what is meant by wire cut?
a scratch on wire ?
or total separated two pieces
Postby eklim » Tue Sep 27, 2011 8:00 pm
is total separate into two pieces. thnks.
eklim
Postby shiyan » Tue Sep 27, 2011 9:37 pm
see a similar post here, same? confusing if you ask the same thing at several places.
shiyan
Postby yonghui » Wed Sep 28, 2011 2:09 pm
separate into two pieces on any point of the kilometer length of the wire?
detecting the voltage on the wire?
Postby eklim » Thu Sep 29, 2011 1:18 pm
ya.you are right.its need to detect the separate into two pieces wire on any point of the kilometer length by detecting the voltage on the wire.
I need to build an device to detect the separated wire (eg: TDR) . So i'm wondering which sensor or other component can be use and low cost.
Thanks
eklim
Postby robosang » Thu Sep 29, 2011 9:22 pm
heheh... that's require research lah.
