Position Sensor
Position Sensor
Postby ELMS » Thu Sep 29, 2011 9:21 pm
I'm doing analog system to control a ball. I'm using IR sensor as the position sensor. The problem is the output of the IR sensor is non linear. How can I invert the output of IR sensor? Should I use anti logarithm? or perhaps linearization formula? Or perhaps just switch to any other suitable position sensor?
Thank you
ELMS
Re: Position Sensor
Postby robosang » Thu Sep 29, 2011 9:30 pm
You should read this article here: Linearizing IR distance sensor
Re: Position Sensor
Postby ELMS » Fri Sep 30, 2011 9:27 am
Thanks a lot. Any other suggestion for sensor? Other than IR sensor? How about ultrasonic sensor?
ELMS
Re: Position Sensor
Postby ober » Sat Oct 01, 2011 11:19 am
ELMS WROTE:I'm doing analog system to control a ball. I'm using IR sensor as the position sensor. The problem is the output of the IR sensor is non linear. How can I invert the output of IR sensor? Should I use anti logarithm? or perhaps linearization formula? Or perhaps just switch to any other suitable position sensor?
Thank you
Position sensor, kind of general term you have there. IR and Ultrasonic range finder is basically distance sensor, not exactly position sensor. In simple words, distance sensor sense distance in 1 axis and 1 line. Position can be 2 D and 3 D. So it depends on how you want it to be 8-)
Ultrasonic range finder resolution is 1inch, so if 1 inch is good enough for your application, then try it, and the output is linear.
Re: Position Sensor
Postby ELMS » Sun Oct 02, 2011 8:22 pm
Thanks again.
ELMS
Users browsing this forum: No registered users and 48 guests
