metal sensor
metal sensor
Postby safuwan jasni » Sun Nov 27, 2011 10:19 am
can anyone suggest me a suitable metal sensor can interface with SK40C with pic16f877A in addition of servo motor.
safuwan jasni
Re: metal sensor
Postby low5545 » Mon Nov 28, 2011 8:01 pm
You can just use this metal detector circuit using the 555 timer IC. A low cost selection. Hope this helps.
low5545
Re: metal sensor
Postby safuwan jasni » Mon Nov 28, 2011 8:20 pm
wow.. its great... but just wanna ask.. did this circuit can connect with sk40c.. because i'm using pic..
safuwan jasni
Re: metal sensor
Postby low5545 » Mon Nov 28, 2011 8:32 pm
should be ok, just remove the speaker and connect it into the IO pin. But the sensor output is a square wave, it differs as it detects metal.
low5545
Re: metal sensor
Postby kl84 » Mon Nov 28, 2011 8:58 pm
How to detect metal with that circuit? I mean which one is the "sensor" in the circuit diagram? The inductor, or capacitor, or speaker, or...? :oops:
kl84
Re: metal sensor
Postby low5545 » Mon Nov 28, 2011 9:24 pm
The site http://www.555-timer-circuits.com/metal-detector.html says that the sensor is the inductor/choke there.
low5545
Re: metal sensor
Postby ABSF » Tue Nov 29, 2011 7:14 am
Since the circuit is simple, you might just construct it and see the effect to judge whether it is suitable for your need. I guess the circuit is outputing a continuous tone and when the inductor is brought near a metal, the inductance would change and thus changes the pitch of the tone. So you need some kind of op-amp circuit with rectified output to convert it to a logic H or L when the wanted tone is detector. You might also need a band-pass filter between the 555 and the op-amp to select the frequency that you're interested.
It is a simple circuit so the sensitivity may not be satisfactory but anyway it is a good start.
