LM35
LM35
Postby teochiashen » Fri Apr 06, 2012 10:49 am
I want to use LM35 to measure the temperature of liquid, but I have to shield it up so that the liquid does not short the terminal, but I have no idea how to shield it?? Is it shield the pin with tape or something?? I have no idea.
teochiashen
Re: LM35
Postby ABSF » Fri Apr 06, 2012 12:24 pm
Is the liquid you're taking temperature corrosive? If the answer is positive, then I would solder 2 wires to the LM35 and insert the whole thing in a glass tube. The tip of the glass tube can be sealed with epoxy that you can buy from hardware stores or supermarkets.
Re: LM35
Postby robosang » Fri Apr 06, 2012 4:55 pm
Yup, check the liquid whether is corrosive or not. If it is not, can simply use glue-gun and shield it up, of course after you solder and test it. But the glue is heat isolator, so not good! 8-)
Maybe can try shrinking tube with one of the end shield with glue-gun.
Re: LM35
Postby teochiashen » Fri Apr 06, 2012 7:36 pm
Then how about the DC water pump that I want to control it by relay? Can i do the same thing to shield the connection between the relay with the water pump under water?
teochiashen
Re: LM35
Postby ABSF » Sat Apr 07, 2012 11:06 am
If the water pump is designed for aquarium use it should be water-proof. The connectors can be put inside heat shrink tubbing and shrink with a hair dryer. If for long term use, the connections should be checked regularly for rusty contacts in case water seeps through the heat shrink tubes.
Re: LM35
Postby teochiashen » Sun Apr 08, 2012 12:53 am
I see. Then if I use glue gun to shield the connector, is it okay?
teochiashen
