Sensor suggestion
Sensor suggestion
Postby tylim » Fri Apr 06, 2012 5:48 pm
hi there
i need to sense, for example, a waste truck, whether it is empty or not
which kind of sensor is suitable?
what i got in my mind is an ultrasonic sensor, but as we know, the waste truck container is thick, i don't know the sensor is powerful enough or not
Please suggest a suitable sensor and state the reasons why :?:
thank you
tylim
Re: Sensor suggestion
Postby ABSF » Fri Apr 06, 2012 6:08 pm
What about taking the weight of the rubbish. How much weight can a 10-ton truck carry?
May be you can use straight line light beams (laser) installed horizontally near the roof of the truck at 4 or 5 positions. If 80% of the light beams are block, the truck is considered full. The problem is what kind of photo sensors can detect laser beams.
Postby tylim » Fri Apr 06, 2012 6:15 pm
hmm, my case is very similar to the waste truck case
the container is a closed space, and the container is thick, and i am not allowed to access the container, so i don't think that the photo sensor will do the trick :|
tylim
Postby jglee » Wed Jun 27, 2012 6:41 pm
how about a pressure sensor/ weight sensor that weights ur load?
When an empty load, it will weight certain weight, and with full/ half load, it will produce some weight. Acceptable?
jglee
