load sensor connect with pic16f877a
Postby areebee » Fri May 04, 2012 8:28 pm
hi guys
really need your help
actually im doing trolley robot
which using ultrasonc, load cell and lcd
so
for load cell,
we need extra circuit or not to connect to pic??
so how about the code?
does anyone have done this project before???
areebee
Re: load sensor connect with pic16f877a
Postby yonghui » Fri May 04, 2012 10:49 pm
what is load cell?
Postby royalstorm7 » Sat May 05, 2012 9:49 am
hi...i did last time...the advanture is there....sure u need xtra circuit..!
royalstorm7@yahoo.com
0 - 50 kg load cell circuitary
royalstorm7
Postby holy_rainman » Sat May 05, 2012 11:18 am
If i'm not mistaken, you would need a voltage divider to make it work. If the load cell have 3 wires, then i believe you don't need such circuit. Try google voltage divider theory and you'll know what i mean.
holy_rainman
Postby shahrul » Sat May 05, 2012 9:36 pm
holy_rainman WROTE:If i'm not mistaken, you would need a voltage divider to make it work. If the load cell have 3 wires, then i believe you don't need such circuit. Try google voltage divider theory and you'll know what i mean.
The voltage divider not enough to read the difference. The response is very small until ADC can't see the different. I'm confident you will fail to use this method because I have tried before.
The solution is, use special amplifier like royalstorm7 said.
Postby holy_rainman » Sun May 06, 2012 1:30 am
may i know the special amplifier circuit? do you have a link for reference?
holy_rainman
Postby royalstorm7 » Sun May 06, 2012 9:13 am
it just a simple instrumentation amplifier, very less info but just plug and play...ez to used...!
royalstorm7
