IR Sensor using lm324
Postby paipai90 » Sun May 13, 2012 2:05 pm
May I know how to measure the output voltage for blocking and non blocking condition?
Is the output voltage is bigger when in blocking condition than non-blocking?
paipai90
Re: IR Sensor using lm324
Postby shahrul » Sun May 13, 2012 6:06 pm
paipai90 WROTE:Hi,
It depends on your voltage divider. IR Receiver is resistor changes. If receive IR Light, resistance LOW. If no IR Light, resistance HIGH. So, depends on your schematic you do pull-up or pull-down will determine the increase or decrease voltage output.
You can see sample here, IR Sensor.
Postby ober » Tue May 15, 2012 4:58 pm
Try looking at one of our DIY project, PR4, you can download the details description too. It has explanation.
Postby ABSF » Tue May 15, 2012 9:48 pm
LM339 (quad) or LM393 (dual) is more appropriate as comparators than LM324 though LM339 has open-collector outputs. But it has better hysteresis loops built-in.
