How to detect if DS18B20 is permanently damaged?
Postby cfsam » Fri Nov 30, 2012 6:27 pm
Previously I have done a stupid mistake by connecting my DS18B20 to wrong polarity. It turns really hot and then only I realised the mistake. When i switched it back, it is still functioning. However few days later, the reading obtained from the sensor keep showing -127 degree C. I am wondering if it is permanently damaaged? How can I check? :oops:
Thanks. Please help. Need it urgent.
Thanks once again.
cfsam
Re: How to detect if DS18B20 is permanently damaged?
Postby zhenning » Sat Dec 01, 2012 12:17 pm
cfsam WROTE:Hi,
Thanks once again.
Do you have a new one? Use it and see the result? Most likely the old one is gone.
zhenning
Postby cfsam » Sat Dec 01, 2012 4:47 pm
No i only have one. That thing is too expensive compared to LM35. Anyway..just out of curiosity, can I use digital pin 0 or 1 as the input for my one wire? Because I tried to do it before but somehow it failed. I wonder issit my coding problem or it is just impossible to do it.
cfsam
Postby robosang » Sat Dec 01, 2012 6:17 pm
Have you successfully read the sensor??
Postby cfsam » Sun Dec 02, 2012 1:00 am
robosang WROTE:Have you successfully read the sensor??
yep~ but previously using digital pin 3, 2, 11 but later wan to use it at pin 1 or 0...it is to no avail~
cfsam
Postby robosang » Sun Dec 02, 2012 7:49 am
So now just change it back to previous uses pin, pin 3, 2 or 11 to check whether the sensor is working. I don see why pin 1 or 0 cannot be used.
BTW, are you using Arduino? Pin 0 and pin 1 is UART pin and is use for loading program. You might want to disconnect the sensor when you load program.
