Traffic Light Sensor
Postby Marcus » Sun Dec 16, 2012 6:23 pm
Hi guys,
I'm looking for a suitable sensor for my Traffic Light Controller System.
The sensor details are as follows:
- Detect metal objects "like a metal toy car" at any range.
- Produces analog/digital output to the FPGA Board.
My research suggest that I use an Induction sensor. I searched the forums already:
http://www.cytron.com.my/viewProduct.ph ... e%20Sensor
However, I am not sure of whether this sensor would be suitable for my application. Hope to get a response on
the suitable sensor offered by Cytron or any other related suggestions.
Marcus
Re: Traffic Light Sensor
Postby yonghui » Tue Dec 18, 2012 5:19 pm
what do u meant by at any range?
Postby robosang » Tue Dec 18, 2012 10:03 pm
What the use if the sensor can detect car at any range? 8-)
There is no such sensor :mrgreen:
Postby Marcus » Wed Dec 19, 2012 4:39 pm
Well since I'm making a model out of this TLC, I would prefer a sensor which would detect
vehicles at the range of 10mm at least.
Any suggestions?
Marcus
Postby Marcus » Mon Jan 14, 2013 10:17 am
Can anyone here help me out?
Marcus
Postby shahrul » Thu Jan 17, 2013 11:51 am
You read the product page you give 1st post. The first sensor sensing range is 4mm, the second sensor sensing range is 8mm. So, it's meet your requirements or not? If you want atleast 10mm, both sensor can't use.
Postby Marcus » Fri Jan 18, 2013 12:19 pm
But it provides an NPN output signal? What is an NPN output signal? Can it be used for ALTERA DE2 Board?
Marcus
Postby shahrul » Fri Jan 18, 2013 2:37 pm
Marcus WROTE:But it provides an NPN output signal? What is an NPN output signal? Can it be used for ALTERA DE2 Board?
If NPN output, the signl sensor is sinking. To working it, you need to put pull-up resistor.
Postby Marcus » Sat Jan 19, 2013 8:01 am
Ok. So once I connect it to a pull-up resistor, it will be "1" isn't it? What's the expected output voltage for
this NPN signal?
Marcus
Postby shahrul » Sat Jan 19, 2013 8:34 am
Marcus WROTE:Ok. So once I connect it to a pull-up resistor, it will be "1" isn't it? What's the expected output voltage for
this NPN signal?
Output voltage depends on your pull-up. If you pull-up to 5V, the output is 5V or 0V. If you put pull-up 12V, the output is 12V or 0V. That's why NPN output is easy to compatible with any voltage level.
