Water sensor brick
Water sensor brick
Postby lokejeehan » Thu Jan 31, 2013 10:40 am
Hi, I have purchased the sensor with u, but unluckily the sensor cannot used as a water level sensor. The voltage will go to nearly zero when i just dropped 1 drop of water on it, even i use ADC, the different is not significant. Do anyone have an idea to increase the difference? Is it possible if i decrease the pull-up resistor?
lokejeehan
Re: Water sensor brick
Postby robosang » Thu Jan 31, 2013 5:22 pm
What is the initial voltage? Water level but you use a drop of water? Not really understand your statement.
Postby sai169 » Thu Feb 07, 2013 1:49 am
robosang WROTE:What is the initial voltage? Water level but you use a drop of water? Not really understand your statement.
Hi. Need help.
I have buy a Water Brick Sensor. when i connect a sensor and put a drop of water, the sensor not functioning. But when i disconnect the sensor and just short the wire, current can flow and run the circuit wisely. The problem comes when i connect the sensor, it does not working.
Besides that, i have try the other circuit. But when i connect the water sensor, a lane lines of the sensor just "erodible".
so, its 2 problem here:
1) The sensor not functioning when i have drop a water on a sensor.
2) The lane line was "erodible"..
what should i do?
sai169
Postby robosang » Thu Feb 07, 2013 9:49 am
What is the initial voltage when there is no water? 5V or 0V? How you detect the sensor? I do not have the sensor, just curious to know the working condition. You use digital input or analog to detect the sensor?
What do you mean by erodible? A photo of the hardware setup would be helpful.
Postby sai169 » Fri Feb 08, 2013 1:53 am
robosang WROTE:What is the initial voltage when there is no water? 5V or 0V? How you detect the sensor? I do not have the sensor, just curious to know the working condition. You use digital input or analog to detect the sensor?
The initial voltage is about 6~8V. I have been use this circuit.
http://www.google.com.my/imgres?um=1&hl ... x=73&ty=45
erodible. I mean 'corrode'.
sai169
