Flame sensor not working
Postby choohao » Fri Mar 22, 2013 4:19 pm
I just bought flame sensor few days,
i follow the instruction here :
http://www.cytron.com.my/viewProduct.ph ... r%20Module
using adruino mega.
The digital fail to give out reading, the analog can function.
Is this sensor spoil??
Can sent for warranty?
The attach picture showing the time when flame detected.
thank you
This when flame detected
choohao
Re: Flame sensor not working
Postby robosang » Fri Mar 22, 2013 10:41 pm
I don own that flame sensor, but seem to be quite easy from the page that you give, and it has a video to show the working condition.
Can show the photo of connection? Did you turn the potentiometer on the sensor?
Postby shahrul » Fri Mar 22, 2013 11:11 pm
If analog can function, ofcourse digital can function. Just setting the variable resistor. Did you set pin as digital input?
This example use flame sensor.
