how to combine PIR Sensor with RTC
Postby fatinathirah » Thu Apr 11, 2013 2:42 pm
Hello, i need help for my project. I am trying to combine coding for pir sensor and rtc (real time clock). The problem is the program does not read the rtc time correctly. i need help! this is an urgent project. help!!
This is the Pir Sensor Code
int calibrationTime = 30; //time for sensor to calibrate 30s
int ledPin = 13;  //choose the pin for the LED
int inputPin = 2; //choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected.
int val = 0; //variable for reading the pin status
int pinSpeaker = 10; // set up speaker
long unsigned int pause = 5000;
void setup(){
  pinMode(ledPin, OUTPUT);  //declare LED as Output
  pinMode(inputPin, INPUT); //declare PIR Sensor as Input
  pinMode(pinSpeaker, OUTPUT); //declare Speaker as Output parallel to LED
  //PIR Sensor will calibrate for 30s first before start using it
  Serial.print("Calibrating Sensor");
  for(int i=0 ; i  < calibrationTime; i++){
    Serial.print(".");
    delay(1000);
    Serial.print("done");
    Serial.print("SENSOR ACTIVE");
    delay(50);
void loop(){
  val = digitalRead(inputPin); //read Input value
  if (val == HIGH){            //check if the Input is HIGH
    digitalWrite(ledPin, HIGH); //turn LED ON
    playTone(300,160);         //turn the Speaker ON
    delay (150);
    if (pirState == LOW){        //motion detected at what time
      Serial.println("Motion detected!");
      Serial.println("Motion detected at");
      Serial.println(millis()/1000);
      Serial.println("sec");
      delay(50);
      pirState = HIGH;
  else{
    digitalWrite(ledPin, LOW);  //turn LED OFF
   playTone(0,0);
  delay(300);
 if(pirState == HIGH){         //motion ended at what time
  Serial.println("Motion ended!");
  Serial.println("Motion ended at");
  Serial.println((millis() - pause)/1000);
  delay (50);
 pirState = LOW;
//duration in mSecs, freuency in hertz
void playTone(long duration, int freq){
  duration *= 1000;
  int period = (1.0/freq) * 1000000;
  long elapsed_time = 0;
  while (elapsed_time < duration){
    digitalWrite(pinSpeaker, HIGH);
    delayMicroseconds(period/2);
    digitalWrite(pinSpeaker, LOW);
    elapsed_time += (period);
This is the rtc code
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
  Wire.begin();
  setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
  printDate();
  delay(1000);
void setDateTime(){
  byte second =      30; //0-59
  byte minute =      16; //0-59
  byte hour =        16; //0-23
  byte weekDay =     2; //1-7
  byte monthDay =    8; //1-31
  byte month =       3; //1-12
  byte year  =       13; //0-99
  Wire.beginTransmission(DS1307_ADDRESS);
  Wire.write(zero); //stop Oscillator
  Wire.write(decToBcd(second));
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(weekDay));
  Wire.write(decToBcd(monthDay));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.write(zero); //start
  Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void printDate(){
  // Reset the register pointer
  Wire.write(zero);
  Wire.requestFrom(DS1307_ADDRESS, 7);
  int second = bcdToDec(Wire.read());
  int minute = bcdToDec(Wire.read());
  int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  int monthDay = bcdToDec(Wire.read());
  int month = bcdToDec(Wire.read());
  int year = bcdToDec(Wire.read());
  //print the date EG   3/1/11 23:59:59
  Serial.print(month);
  Serial.print("/");
  Serial.print(monthDay);
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(minute);
  Serial.print(":");
  Serial.println(second);
This is the combine code. I know is not that neat and tidy. But there still nothing wrong during the compiling.
#include "Wire.h"
#include "RTClib.h"
byte zero = 0x00;
int ledPin = 13;
int inputPin = 2;
int pirState = LOW;
int val = 0;
void setup(){
  Serial.println("Calibrating Sensor");
    Serial.print(".");
    delay(1000);
    Serial.println(" ");
    Serial.println("done");
    Serial.println("SENSOR ACTIVE");
    delay(50);
void loop(){
  if (val == HIGH){
    playTone(300,160);
    delay (50);
      rtc(); //Serial.print(millis()/1000);
      //Serial.println("sec");
      delay(50);
      pirState = HIGH;
  else{
   playTone(0,0);
  delay(50);
  rtc(); //Serial.print((millis() - pause)/1000);
  delay (50);
 pirState = LOW;
  duration *= 1000;
void rtc(){
  printDate();
  delay(1000);
void setDateTime(){
  byte minute =      01; //0-59
  byte hour =        12; //0-23
  byte weekDay =     1; //1-7
  byte monthDay =    4; //1-31
  byte month =       4; //1-12
void printDate(){
  Wire.write(zero);
  Serial.print("/");
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(":");
Now the problem is as shown in the picture below. it does not detect the correct date and time.
I really need ur help. You may also correct me if there's anything wrong with the coding. Its a process of learning for me. But still i need to finish my project asap! waaaa!!! :'(( I really appreciate ur help!
fatinathirah
Re: how to combine PIR Sensor with RTC
Postby fatinathirah » Thu Apr 11, 2013 10:52 pm
ok found the prob already. i forgot to put wire.begin() before setDateTime() . problem solved. cased closed. XD
fatinathirah
