How to convert analog value of HR202 to RH
PostPosted: Mon Apr 22, 2013 11:24 pm
by ale7beck
Is there an equation to convert the analog value to relative humidity in %?
Re: How to convert analog value of HR202 to RH
PostPosted: Tue Apr 23, 2013 9:33 am
by shahrul
In the HR202 have graph resistance over humidity.
In the circuit humidity sensor module it shows have a pull-up 10K. So, it be a voltage divider.
Microcontroller just read analog voltage. Then, from analog voltage convert to resistance using voltage divider formula.
From the resistance convert to humidity. From the tabulated table, you can get the formula by using Curve Fitting.
Ex curve fitting HSM-20G and Maple Curve Fitting.
