IR Distance Sensor
IR Distance Sensor
Postby akemhkakashi » Sat May 11, 2013 1:00 pm
im working on pick n place mobile robot project
currently im using 3 SN-E18-D80NK interfacing on arduino uno for obstacle avoidance..
im trying to use the same sensor to sense object at different distance, is it actually possible?
the plan is like this, when middle sensor detect far object (30cm), it will approach it and when the distance is near (5cm) it will send signal to arduino so that the robot can grip the object..
if the sensor is not possible to do it, any recommendation or suggestion on other method or sensor?
thank you in advance
akemhkakashi
Re: IR Distance Sensor
Postby akemhkakashi » Sat May 11, 2013 10:22 pm
bump
akemhkakashi
Postby robosang » Sun May 12, 2013 8:36 am
If you are using the sensor, you should know it is degital. The detection distance is preset. It cannot give you distance between obstacle.
Postby akemhkakashi » Sun May 12, 2013 12:24 pm
oh no.. so its just between detect / not detect ?
hmmm any alternative what sensor should i use?
akemhkakashi
Postby waiweng83 » Mon May 13, 2013 11:37 am
You may try the Sharp analog distance sensor: http://www.cytron.com.my/viewProduct.ph ... %20(4-30cm)
waiweng83
Users browsing this forum: No registered users and 17 guests
