CMUcam4
CMUcam4
Postby lan mj » Thu Jun 20, 2013 12:22 pm
Do you have any compatible usb to serial converter that i can use to communicate with CMUcam4; i) if i'm a win XP user ii) If i'm a mac user with OS X
lan mj
Re: CMUcam4
Postby yonghui » Thu Jun 20, 2013 3:38 pm
Re: CMUcam4
Postby lan mj » Fri Jun 21, 2013 4:52 pm
O..TQ...for more details, how to connect four pins at UC00A (Vsel, GND, TX, RX) to the CMUcam4 board? Which pins should i use ?
Since there are two column of six pins on the left side of the board; first column pins => TX0, RXI, DTR,GND, Vin, GND; second column pins =>DTR, TX0, RXI, Vcc, CTS, GND;...Which four pins should be connected with UC00A ?,...Please help..thanks
lan mj
Re: CMUcam4
Postby yonghui » Mon Jun 24, 2013 12:40 pm
i think u will need to check the usermanual of cmucam. most basic serial communication connects Tx to Rx and Rx to Tx. from your description, u have 2 pair of serial com pin on cmucam, so u will need to check which is for what.
