Ultrasonic Ranging Module
Postby MystizKhoo » Thu Aug 08, 2013 1:43 pm
Can multiple Ultrasonic Ranging Module from Cytron able to run together in PIC16F877A?
Imagination should be used,
not to escape reality,
but to create it.
MystizKhoo
Re: Ultrasonic Ranging Module
Postby yonghui » Tue Aug 13, 2013 5:45 pm
ya i think can. just connect sensor to different analog channel of pic16f877A. then read the value from each channel.
Postby robosang » Mon Aug 26, 2013 1:51 pm
which ultrasonic is we talking about? Please give actual URL.
Postby chingfa » Sun Oct 20, 2013 12:37 am
hi, how can i simulate ultrasonic ranging module in protues???? Helpp...
chingfa
Postby zeeshan » Fri Jan 02, 2015 3:34 pm
What sensor do you suggest for me to record the movement of my robot? I am using Arduino Uno.
We offer up to date Testking prince2 course exam practice questions with self paced test engine to help you pass Testking mcse 2008 exam and complete your ccent course Stanford University itil? Get our self paced bu.edu you should also find.
zeeshan
Postby yonghui » Mon Jan 05, 2015 7:44 pm
What do u meant by record movement? How far? Direction?
Postby 2015851598 » Thu Oct 26, 2017 5:30 pm
Is the low cost ultrasonic in your catalog can detect any piece of paper ? How far its sensitivity? My capstone project is about to built the smart assignment box and need any suggestion for suitable sensor that can detect non metallic object like papers.
Thank you
2015851598
Postby sich » Thu Nov 02, 2017 10:20 am
What's the end goal of the project? Differentiate paper from stone, detect the existence of paper in an open air, determine the distance between paper and sensor?
Take a look at this video https://youtu.be/3ygzks1vBts?t=218, especially the last part.
Postby vidya shini » Mon Feb 19, 2018 4:31 am
Hi i Want a Project tutorial that calculate
The Height of obstacles that i fixed if It detect different Type of Height It should Send MSG using GSM mudule Sim 900A..
Using arduino and ultrasonic Range maxbotix and High Range maxbotix...
Need Code and Circuit diagram...Thank you
vidya shini
